x-over, hi steer and hydraulic installed.....Death wobble?
ZK5
Meriden, CT
I recently installed the crossover steering, hi-steer and hydraulic assist for my 60 and I finaly took it for a test ride. As soon as I hit 25 mph or the first bump the truck wobbles so hard that it yanks the steering wheel out of my hand. I replaced the king pin bushings and washers only cuz I had new ones layin around it didnt help at all. The pins looked good and I dont get any play from the lower bearing and pin. I aligned the front wheels the best I could with a tape measure and they appear to be right on. Should I invest in the complete king pin set or a 4 wheel alignment first?
/forums/images/graemlins/shocked.gif
[ QUOTE ]
[/ QUOTE ]
Whoa, this happen to anybody else? I thought crossover and hydro assist deleted the death wobble problem. Death wobble is the main reason I was going to crossover w/hydro assist. /forums/images/graemlins/shocked.gif
What about tie rods ends? I had this same thing with my crossover (not a d60) and had the front wheels balanced and it helped dramatically.
all the above plus check the toe again, you should have some toe in, probably 1/4" or so wouldn't hurt to try.
Maybe try with different tires to see if it changes?
