popping sounds
So I got the XJ shaft good and tight now. New ball joints, recentered the steering, rebuilt steering box, new steering stabilizer (ORD steering brace is next). The truck now steers way better than it has since I've owned it. Only thing is, since I went back and tightened up the pinch bolt at the top of the XJ shaft, I hear a popping sound when I turn the steering wheel in either direction. It's not really loud, but you can hear it pretty good when you're going slow or turning the wheel while the truck isn't moving. I didn't notice this sound until I tightened the crap out of the pinch bolt on the XJ shaft, but I can't tell if that's where the noise is coming from. Could be coincidental. Has anyone else experienced this sound? Should I be concerned?
