XJ steering shaft...
wetbackZO
Las Cruces, NM
which year XJ's steering shafts will work on our GM trucks?? I want to eliminate the rag joint on one of my trucks cause I'm putting a body lift...TIA!!
XJ is a POS...otherwise known as a Cherkokee. :D
Rene
We had an '88 for 5 years...it's not 'preference' or brand loyalty speaking, it's personal experience.
Rene
Are there any sites that show, or dose any one have any picutues of the modifacation to the steering colum side to make this work?
If you look in this picture you can see where the clamp bolt protrudes into the Double D area.
All you have to do is put the shaft in place and take a drill bit and clearance the steering column shaft to allow the clamp bolt to slide into place. Take care to not damage the threads on the other side. I chased the threads with the bolt after I did mine to ensure no problems. You really dont have to take that much off and could prolly use a file. A drill for me however took about 30 sec.:D
Ira
josh86k10 said:
Hey now...careful
No kiddin:o
Although I never drive it anymore, I am puttin a bunch of Chevy stuff under it and doin an exo to make it last. My burb will be the tow/camping/recovery vehicle.
Anyone with a 70's gearbox with the smaller input shaft done anything simmilar ?
I have 70's box and ragjoints , and 80's box and ragjoints . The 80's are larger in diameter at the shaft on the box .
damn...I thought the XJ shaft was just a bolt on, as soon as I get to it we'll see how it goes. If it don't fit, I got a chop saw and a welder to make it fit:haha:
my parts for my next one is from a wrecked 98 durango lol
also to any xj fans I discovered the durango box 98-99 will bolt up in place of a factory xj steering box...much beefier
