Just got back from the junkyard to pick an XJ shaft up. Interesting side note: Jeep Comanche steering shafts look absolutely identical to the '87 XJ shaft I pulled out today. Didn't happen to get any pictures, but they're the same length, and have the same input shaft end styles - a chamfered/oval square, and a splined input. Not sure if that'll help anyone, but the junkyard I went to had 5-6 Comanches and only 1 XJ.
Anyway, on the Blazer, what's the correct method to pull the steering shaft out? Wound up dropping the steering box out of the Jeep to get the shaft out, and I'm hoping it's not necessary to do that to the Blazer. Also, what's the correct method to "free up" the two seperate shafts on the XJ shaft without fubar'ing the u-joints? The plastic clip is gone, but the shafts seem stuck together pretty good...not sure if it's just gunk buildup, or if there's something else that needs to be taken off before I can collapse/expand it to fit the Blazer.
First real junkyard excursion, and I wound up picking up a bunch of stuff I didn't plan on, and I'm going back next week to get even more parts
