Ok so I have the ORD xover steering and love it...however I have been battling a delema for some time now (although the truck has not seen any movement in a year!!!!)
that delema is my power steering keeps on leaking out... emptying the entire pump out.....
ok so I have a new pump, both hoses and belt.....
still happens...
I have started the truck up and with the wheels in the air... turned both ways and held it there to bleed the line......
I can clean the engine cross member and pump.... and after starting the truck I see it dripping out off the cross member.... right from the fill tube...
so Since i replaced the pump and hoses... I figured that would fix it but it didnt....
so now im thinking there is a problem with my gearbox.... and I think I have an idea of what the issue is.... I put a 2wd gear box shaft into my 4wd box. I couldnt get the bolts and hoses off back then but couldnt so a simple shaft swap did the trick....
now i wonder if the middle adjustment (shaft play?) if that is out of adjustment creating back pressure...
so what do you think?
still happens...
and then the leak just disappeared. I never figured out what it was though
