Not off the top of my head. Jus check LMC online.
********************UPDATE*********************
Well, that was more daunting then I had invisioned. I must say that really sux'd. I finally got it all done. This is a tidious task. Expect LOTS of time to complete it. Ive got about 5.5+ 3. So, ive got 8.5 hours in jus putting this IN. I had stripped the interior previously, expect the carpet itself, but removed all the seats, etc prior to putting this in. Like I said earlier, that back 1/2 is jus like putting a rubber mat down in a truck bed, expect the rear seat stuff.
Oh, and good luck finding and lining up the holes you need. lol. This mat has nothing to indicate where anything is. Its not really form fitted like I had thought it would. It does fit loose like I thought up around the foot area of the driver and passenger. It is nice to slide right in and out of the Blazer though and the black looks cool.
How I found the holes underneith was like this. I would run my hand under the mat and locate the holes with my finger, than I would use a thin hole punch and push from the top, feeling the pressure on my fingernail (most sensitive part of the hand BTW), As you are moving the punch around and pushing down (your not tryin to push thru, jus feel for where the hole is). you will know when your on top of your nail that is over the hole. You hold the punch in place, remove hand and punch thru. In the beginning I was only off by cm, but near the end I had it down pat. Then I would take an Xacto <sp> knife and cut out the smallest square over the hole that I need to get the bolts thru. After awhile I got better and quicker at this. In the beginning ya gotta go slow and be careful, that sucka is sharp.
As far as the insulation, i got the roll that LMC sells for like 29bux. It covers MOST of the cab area, but where the back seat ppl sit though. But my Mat came with insulation like the factory had, but its only enuff to cover the compete cab section, there was no insulation in the back section and I didnt put any back there.
As far as cutting thru the insulation, it aint goin to happen. Once I got the hole cut thru the rubber mat, I jus used the same hole punch in wiggled it around the hole and moved the insulation outa the way with it. like reaming it somewhat. This worked well. sometimes I would have to tap or push on the bolt to get it past the insulation and onto the threads. Below are some hints and tips:
1) Xacto knife and thin hole punch were all that was needed (other than the wrenches to put OEM parts in/out) but those two items are all you need to properly fit this.
2) Do not trim the Edges until the very end. I made a mistake and tried to trim it to fit b4 putting seats and everything back in, ive got a lil gap on the pass. side wheel well that Ill need to cover up (its bare floor now), ive got some extra rubber mat that ill toss over there and maybe glue to the existing mat.
3) Cut the 4wd shifter hole first, base the whole placement of the mat off of this.
4) Expect to invest lots of time into this, im no expect, but ive done my far share of auto mechanics.
Pics coming soon, i needed a break, lol.
