joshthemule
What year range 3/4 ton burban had the full float axle. I was thinking that they switch to the semi float on later models but I'm not sure. I'm trying to figure out what brake lines to order from LMC. I've got a 91 suburban with 14BFF from a 85 5/4 ton CUCV (which is the same as a 1 tome truck) LMC has no parts listed for 1 ton trucks but I'm sure they are the same if the axle is the same.
