Yoke/14BFF Question.
flynn78us
Cape May Court House NJ
What is the yoke on a 14BFF? And can I buy the 10 Bolt size yoke for a 14BFF? That would be in my mind stronger than a conversion joint. Thanks for your input.
Mike
14 bolt should be 1350 as for going to a 1310 like a 10 bolt. Don't think you will find one. The conversion joint should be fine, As long as your pinion angle is good.
i had built 400sbc with good heavy built th350 and 205 with 1tons swaped in 1/2 truck. and 4.10 with detroit in back. i use to beat the heack out of it all the time.
never broke the trick joint on my drive shaft.
