yokes for a 208/241
All you have to do is find a 3/4-ton or 1-ton truck and it will have 1350 yokes.
I don't know what the slip yoke part # is, but for fixed yoke, I think it's Spicer 3-4-6211. Look on about page 16 of the Spicer yoke catalog
That would fit the front output for a non-CV front shaft or a fixed (non-slip) rear output.
For the rear slip-yoke or the front C/V style yokes, just hit a junkyard.
Are you referring to the front output. My 90 3/4 ton burb had the sm465/241 combo. I'll check to see what the front has. I know the driveshaft ujoint on the front axle side is a 1310
ratzila said:
Are you referring to the front output. My 90 3/4 ton burb had the sm645/241 combo. I'll check to see what the front has. I know the driveshaft ujoint on the front axle side is a 1310
yea front, Im doing the 56 front spring swap so Im getting a new driveshaft from HAD and dont want to run 1310 ujoints I would love to run 1410 but Id be happy with 1350, but I need the yoke first
I just realized the front has the flange cv so I'm not sure what yoke that would be :o
I dont think they made a 241 or 208 with a yoke for the front output, just a flange, and the rear output on was fixed in some dodges unless you get a SYE for the 241.
Since you are already getting a driveline from HighAngle, I would suggest asking Jesse what he can do to the flange/yokes. I got a front driveline from him with a 1350CV with flange for my 208 transfer case... :)
