Zero Rate or thick overload springs?
jeff in co
Colorado Springs
I'm thinking either a zero rate or "this" spring. Looks to measure about 3/4". I'm wondering if I bolt this to my stock spring pack if it will contribute to the ride? Because it's on the bottom and no other springs are touching it (without a ton of weight in the truck), I'm thinking it wouldn't add to the ride....being stiffer. Is my logic correct?
I went down from 35's to 33's and want to remove my 2.5" lift blocks but would like just a little "something" in extra height.
Here it is with the new 33's and Rally's. Still at about 2.5" lift. I have just a very slight vibration and with the t-case dropped right now, I'd like to get it back up and see if the vibration goes away.
