Zero rate question...
Drill a hole in the shim for a socket..
Or tack the bolt head to the zero rate.
or bolt up the shim sideways, attach zero rate to spring pack. hammer shim in correct spot
get a longer bolt for spring pack, hold the end with vise grips and tighten nut with wrench
I might do option 3, I don't think I need it real tight as I still have the clamping force of the ubolts.
