zero rate
used to be a couple places sold the 1, 1.5, and 2" zero rates. Maybe diy4x could cut you a set
At 2" your into a block and it would only be safe for the rear axle. the 1" zero rate has been accepted as usable for the front as well due to the center pin going through the entire leaf pack
I have 3" if your interested.
these are lift blocks , by the way.
sorry to lead anyone to think otherwise.
Im pretty sure black widow performance used to sell them, and the 2 & 3" ones he sold just for rear apps, angle milled if needed blah blah blah. Who made yours scrappy?
This title is perfect for me. I have a v30 crew and want 6 inches of lift I am going 6in springs in the front and a shackle flip in the rear but do not know if I can get the other 2 inches from a zero rate or should I just use a 2in block And am I even going to need a zero or not? Thanks shoe81
it's usually best to stay away from blocks. Depending on the wheeling that is but you could get a longer shackle and the zero rate and that would give you the lift you want
Yeh I just found an old thread on another site and black widow is who Im thinkin of, they made em in 1, 1.5, and 2
