Zero Rates ??'s
Big10
Valdosta, Georgia
Zero Rates ??\'s
Im sure this has been covered, and i have searched, but found nothing to fit "my" application. I have a 4" rough country lift (all spring), my t-case has not been moved/lowered. The driveshafts have not been altered either, I have about 1 inch of spline showing on the front and the back shafts. I want to add zero rates to the front to allow a little more clearance, and some in the back to keep the truck level. Am I going to run into trouble with drive shaft length? Pinion angle? vibration? thanks for any input.
Re: Zero Rates ??\'s
Same here, so I'm wandering the same deal (before I get the 4" all spring lift in) /forums/images/graemlins/deal.gif
Im running Superlift 4" springs and a ORD flip, when i added the zero rates i mover the front foward the 1.5"s and had to get the shaft extended 2"s, the back was fine but the flip might be deffernt than your springs as far as pinion angle gos
