R
RIPPEDK5
Guest
I had been kinda misled I think about zero rates. First I see them being put both in front and rear suspensions for height. You call them "zero rate" because why? Far as I knew regular steel or aluminum blocks had "zero rate" or no spring rate to them? arent these just blocks? and arent they unsafe in the front under the spring?
I dont believe the answer, " well they have pins to center and hold their place"--> so do blocks!
Someone please explain these "blocks" and why they are called "zero rates"
thanks
thanks
