in light of recent posts (
), and the numerous PM's I get pertaining to the product, I thought I'd throw out some of my findings, etc after using the product for decades...
as to prep.... gritty is good.... sometimes...
here's why.....
if zinc chromate is going to be used strictly as an etching primer and have a filling primer on top of it, you wont need to worry about sandscratches showing thru, or even a heavy gritblast, as the fill prime will take care of anything...
the courser the cut, meaning the lower grit #, the better ANY autobody product will adhere... I usually prep raw steel with 80 grit on a DA for a zinc/fill application..
stupid small part you don't wanna bother with a fill prime? a little lighter on the grit and a couple extra coats of the zinc... paint right over the zinc...
this leads me to mil thickness and windows of application.......
generally, in a perfect world, your parts wont be green long.... you zinc em, come back in an hr once they've flashed off and overcoat them with your filling primer... a "wet on semi wet" app as I call it.. in this case, you want a minimum of mils, just a pisscoat is all thats needed... 2 thin coats...
now, for the rest of us in the not perfect world, parts may sit... if the zinc is going to be uncoated for more than a day, IT SHOULD/LIKES TO BE, SCUFFED OR SANDED before the next app, either paint or fill prime... doesn't have to, but likes it...
course scuff pads work the best.. 3M's are the maroon.... you can sand it in a pinch, but it's easy to go thru to raw steel...
this brings up the last point.. perfect world, the application should be thin enough that exposure to weather, etc will allow rust eventually....
sitting around for weeks and plan on having to scuff it? put double the primer on... it now holds up to any moisture VERY well, and gives you some material to scuff/sand when the time comes...
I wont bother with getting into 2-part washs, etc unless we need to.....
comments, questions, feel free... if I remember anything else thats pertinent, I'll post back up...
), and the numerous PM's I get pertaining to the product, I thought I'd throw out some of my findings, etc after using the product for decades...as to prep.... gritty is good.... sometimes...
here's why.....if zinc chromate is going to be used strictly as an etching primer and have a filling primer on top of it, you wont need to worry about sandscratches showing thru, or even a heavy gritblast, as the fill prime will take care of anything...
