The LS7 is a 427 used in the 2006 and up corvette Z06. It is also available in crate engine form.
7.0 L
LS7
7.0 L LS7 engine in a 2006
Chevrolet Corvette Z06
LS7 can also refer to a 454 CID Chevrolet Big-Block engine of the 1970sThe
LS7 is a 7,011 cc (7.011 L; 427.8 cu in) engine, based on the Gen IV architecture. The block is changed, with sleeved cylinders and a larger 4.125 in (104.8 mm) bore and longer 4.00 in (102 mm) stroke than the LS2. The small-block's 4.4 in (110 mm) bore spacing is retained, requiring pressed-in cylinder liners. The crankshaft and main bearing caps are
forged steel for durability, the connecting rods are forged titanium, and the pistons are
hypereutectic. The two-valve arrangement is retained, though the titanium intake valves by
Del West have grown to 2.20 in (56 mm) and sodium-filled exhaust valves are up to 1.61 in (41 mm).
Peak output is 505 hp (377 kW) at 6300 rpm and 470 lb·ft (640 N·m) at 4800 rpm with a 7100 rpm
redline[
citation needed] During GM's reliability testing of this engine in its prototype phase, the LS7 was remarked to have been repeatedly tested to be 8000 rpm capable, although power was not recorded at that rpm level, due to the constraints of the camshaft's hydraulic lifters and the intake manifold ability to flow required air at that engine speed.
The LS7 is hand-built by the
General Motors Performance Build Center in
Wixom, Michigan. Most of these engines are installed in the Z06, some are also sold to individuals by GM as a
crate engine. They were also exported for use in the Australian built
Holden Special Vehicles W427.
After an extensive engineering process over several years, Holden Special Vehicles fitted the LS7 to a special edition model, the
W427. The HSV-tuned engine produces 375 kW (503 hp) and 640 N·m (470 lb·ft), making it the most powerful car ever built in Australia. The W427 was unveiled at the
Melbourne International Motor Show on 29 February 2008
[8] and went on sale in August 2008.
Applications:
LS7.R
The
LS7.R engine is a variation of the LS7 used in the highly successful
C6.R American Le Mans Series racecar. It was crowned as Global Motorsport Engine of the Year by a jury of 50 race engine engineers on the
Professional Motorsport World Expo 2006 in
Cologne,
Germany.
