Restomod 83K5_blazer (she’s back!)
Rust repair and trying to un-f*ck everything the PO's had done.
Here is a build guide to help anyone out:
Start of rust repair
Hard top repair/ restoration
ORD 4” lift (front end)
I'm calling this the "Rednecked Resto" due to the condition this was in when I got it. Hacked up wiring throughout, pieced together seats from three different trucks. Rocker and floor rust and it had been primed over primer several times. This will be converted to a full vert truck using a 74 top and header frame.
1983
K5 - Blazer
YE9 Silverado
Silverado - A/C
Currently:
350 c.i. - 14010207 block
Holley Street Warrior 4160 600cfm Carb
Edelbrock Performer EPS 2701 Intake
Summit HEI Blueprinted Distributor
Taylor Street Thunder 8mm wires
TH700-R4
Factory
4” Tuff Country front springs, ORD HD front shackles, ORD FUSH kit, ORD swaybar disconnect kit, Bilstein 5125’s.
Factory 10 bolt 6 lug
American Racing Outlaw I 15" x 10”
Mickey Thompson Deegan 38 MT’s - 33x12.5x15
Factory - Midnight blue/ white top
Currently a mix of primer and Vvivid vinyl wrap
Cntymnty77
7,345
2
