Sure enough, looks the same!
WOW! Thanks for posting. That build is a treasure chest of ideas and info.
The struggle is real!Oh my gosh, how will you ever repair that.![]()
What did you end up doing for the engine crossmember?Harness is back on. More parts are on order.
I still need to build it. I measured the frame width and it’s the same as my ‘84 so technically I could make an ord one work but it has more drop than we need and usually requires at least a 2.5” lift. I’m going to make a copy but tighter up. I’ll post pics when I do itWhat did you end up doing for the engine crossmember?
No, I couldn’t find a pwm pump module that was deep enough for this tank. I used the universal fitech pump module that’s adjustable for depth with the corvette fuel filter/pressure regulator. What they sometimes call a “LS” setup.Did you go with a PWM fuel pump? Part number?
PWM fan number also.
I am a little behind still.
We’re just using the stock replacementThanks.
What radiator are you going to use?
Haha, shouldn’t be a problem.I am hopeful that my factory 5 row is ample. Should be.
