They are either taller or shorter I believe. The medium duty trucks run a different location for the belt. Like either closer or further from the block than the passenger applications.What is different about the water pump on a Kodiak? That look like mine
You are correct. The PS and alt brackets came from Russell in CanadiaThat at least looks like a light medium duty ps bracket. It uses a normal Saginaw pump vs the heavier trucks using a massive ZF pump.
Wes the med duty/workhorse/g-van brackets do take specific matching water pump and balancer since it does away with the secondary ac belt setup.
I’d keep that medium duty one around. The ZF pump would be complete overkill to run with a full hydro steering setup and hydro boost brakes on something like your dedicated wheeling rig.You are correct. The PS and alt brackets came from Russell in Canadia
This is the bracket that came with this Kodiak donor. It’s a ZF/Allison 2000 next to the one I’m using.
I’d keep it for your first blazer you put the 8.1 in. I don’t remember if you went full hydro or even hydro assist on that one yet.So you are saying keep it for a street/tow rig?
It’s full hydro.I’d keep it for your first blazer you put the 8.1 in. I don’t remember if you went full hydro or even hydro assist on that one yet.
