I will leave that comment alone just for Dean.
I got no problem with long term projects.
Just post a pic once in a blue moon!?
One day in my 76, the little rod in that the key tumbler connects to, broke. Does the key just not do anything or does the feel of the key seem to be light?New harness swapped in, still no cranking at the key. I’m thinking there is an issue from the column side of things.
Park/neutral switch maybe?
Switch out of adjustment or even the mechanical not working right
Can you hear the Cam and rod rotate?
Winners! Jumped the plug and it fired right up!My guess. I had to jump that on my k20
I was saying it would be a opportune time to make fun of Greg and his 10 year SAS.
Small test drive to the road and back revealed a frozen shock and zero turning radius. So some trimming and shock removal are next on the list.
The build is over. Nothing to report.Actually I was referring to your Chevelle build...![]()
Don't trim it !!!Small test drive to the road and back revealed a frozen shock and zero turning radius. So some trimming and shock removal are next on the list.
What ? Trimming? No...
Don't trim it !!!
You will regret it later!
Just like you regret beating up the k5. Keep this one as a nice driver!
Exactly what Luke said. It’s Rusty, so only a small amount of trimming while it sits as is. Then the 4” lift and new panels with zero trimming.If it is as rusty as it looks then trim away! No harm in removing the rusty bits.
That’s a crazy good deal! Hopefully there is a deal like that when funds recover.
Decided to decode the vin this morning. I am really hoping this is the original engine as the 3rd digit on the vin(U) shows this should be a 400ci engine!!!
I know it has a 203 t-case, but I didn't even think to look for a Th400! Now i'm curious.That would be tits!
Did it come with a th400 then too?
No man pedal?I know it has a 203 t-case, but I didn't even think to look for a Th400! Now i'm curious.
No man pedal?
No not yet. This would get an NV swap if anything.
