‘82 GMC “Junkyard JIMMY” {Build bash Rebuild}
I use to drive by Surplus Center almost every day. It seems weird to me that people all over this board buy parts from them.
Martin
I was thinking that as I pass by 3 hydraulics stores and 2 hose pros trucks per day here. :popcorn:
The way I see it is if these guys have a good reputation here, I don't mind giving them my business.
...still waiting for discount hydraulics. :doah::haha:
Order confirmed on 9-16-12
paid an extra $10 for 3 day S&H
Request for ETA sent 9-25-12
Response on 9-26-12 Was "we just got your parts in, we are sending them out today".
The interweb said the parts were in stock.:whistle:
12 days and counting...:popcorn: :sign19::zombie18::zombie13::zombie4:
ImageUploadedByTapatalk1349309361.187591.jpgImageUploadedByTapatalk1349309548.954836.jpg
I think the new fitting are for the wrong size hose. The male end is way too big to fit in the hose.
I should have ordered 1/4" hose x 3/8 JIC. I ordered 3/8" hose x 3/8 JIC. Sum beotch.
I think those are the right ones.
Did you try threading the sleeve over the top of the hose? Not the piece that goes in.
Yes sir, I threaded the outer sleeve over the top of the hose. It is the correct size.
The inner piece is way too big to fit inside the hose. It doesn't even come close to fitting. The ID of the hose is about 1/4" the OD of the inner fitting is about 7/16".
The 45* fitting you gave me works. It should be the same size eh? :dunno:
It's a different style I looked at mine this morning the fittings that I got from them were much beefier. But they were the right ones. Little spit and pressure ;) that hose I gave you is 3/8. I'll bet my life on it.
Well Sir, you were right. :bow:
Yer smart,I'm stoopid
Yer right, I'm wrong.
You have wisdom beyond your years, I'm still wet behind the ears...
I managed to get the hose end adapter on after all.
It only took 1 beer, 1 shot of Honey jack, :smokin2:and a little bit of lube.
Like most dates, it starts with just the tip and ends with full penetration.
There's a trick to it.
Want to hear about it?
Hahaha I'm concerned about about how much honey jack was consumed after the work and before that post
I got the tapped 2wd box installed.
My frame is crack free.
Next I need to take some measurements for the Norcal_Chris cross over.
