‘90 Suburban Denver
Rescued from Colorado.
Stock Rear shackle hangers are removed.
Will get the flip kit on tomorrow and axle swapped out. Wheels and tires should be here Tuesday hopefully.
I messed up when I was ordering steering parts. I didn’t realize my pitman arm and steering arm had draglink tapers. I ordered the ord ends and they are tierod taper.
So… back to the order board.
The tires are Toyo open country r/t trail.
My lugnuts haven’t shown up yet so i had to rob half from the K5 haha
Next on the list to finish is drivelines.
Front shaft is about 6 inches to short and will need the long slip option.
Rear shaft length is actually fine and it bolts up, but the axle I swapped in has its pinion pointed up at the t-case for a double cardan shaft. The burb has the stock 241 slip yoke with single joint. I dont even need to drive it to know how thats gonna vibrate. So… guess ill get a sye and have a double cardan shaft built.
Pay Me Kim Kardashian GIF by GQ
