This thread is for the general discussion of the Item ‘91 FWC K5. Please add to the discussion here.
Dang, that stuff was hidden for sure. Bright side that it appears to all be hidden flat panels.hoped for better but not too far gone for sure
That was my initial thought but I got to reading larrys writeup on the 8.1 and my understanding was id need x year 8.1, y application accessory drive setup, z manifolds etc, didn’t exactly sound like I could find a single complete engine setup that would be the best fit for a k5, am I misunderstanding that? Sounded like alot of piecing together the right 8.1, is that not exactly the case? Ideally a very mildly tuned stock 8.1 and 4l80e wasI was hoping for. Id love a diesel but that gets rather involved quickly, my 5 speed swap on my last k5 the pedal assembly swap was my least favorite part, took longer than swapping the trans itself lolBig block. Though I’d go L29 7.4 or 8.1 L18, keeping fuel injection. Hear me out since it sounds like you don’t want to deal with efi. If you go stock in either situation, standalone harness and factory ecm with a light tune, it’s turnkey. I don’t mess with fiddling with fuel maps or timing tables. It works just like Gm intended. Hot or cold, high elevation or low. Parts are available at any local part store too.
It’s like an LS swap, but better because it’s a big block and not an LS.
Yes and no. It really depends on what you want to do. Outside of the little changes around the cam sensor and timing cover it really just comes down to getting the right harness for the year of the 8.1. The accessory drive depends on if you want ac or not. The truck setup runs the ac compressor separate from the main belt and puts it low on the block like an LS engine. That won’t fit on a square. So if you don’t want to run ac it’s an easy find. Otherwise if you want to run ac you need to find the accessory brackets from a van or a workhorse rv. There is someone making them too.That was my initial thought but I got to reading larrys writeup on the 8.1 and my understanding was id need x year 8.1, y application accessory drive setup, z manifolds etc, didn’t exactly sound like I could find a single complete engine setup that would be the best fit for a k5, am I misunderstanding that? Sounded like alot of piecing together the right 8.1, is that not exactly the case? Ideally a very mildly tuned stock 8.1 and 4l80e wasI was hoping for. Id love a diesel but that gets rather involved quickly, my 5 speed swap on my last k5 the pedal assembly swap was my least favorite part, took longer than swapping the trans itself lol
, only marking I could easily find was a W in the front corner by hole 1. It still runs like sheit, almost dies occasionally off the line, idles great still. Floored at high rpm it makes less power than my 2.3 ranger.aluminum angle plug head crate engine
Maybe these.Any idea what heads they are? Im not finding anything, not sure what its worth but the part number on the plug came back for a 96-98 I think corvette, that was the only 5.7 factory application rest were ls trucks
Ive got my eyes on a 4bt with a gm adapter housing, thinking about an sm465.
Hopeing to fix that with the 3.73s and 35sNon OD tranny will suck here IMO if you plan on doing highway speeds.
