Be warned, Milwaukee drills have different strengths. I had a Magnum Hole Shooter, that drilled everything I needed and then some.
But, I was doing some work and needed two drills, and my 3/8s B&D could not cut it.
So, I started looking at some Milwaukees. Found this one.
http://www.amazon.com/Milwaukee-030...e=UTF8&qid=1353031322&sr=8-1&keywords=0302-20
This is one scary drill. Its smaller than my Magnum, but way stronger. NEVER use it without the side handle!!
It
will hurt you.
I think if you could hold it, and connect it right, it would spin start a big block.
Friend of mine has scissor style jacks on his big camper. He has a handle he gets out and puts in each jack and cranks them up.
I build an adapter for this drill, and if you get a good grip on it, it will spin them right up.
He brought the camper to my farm last year after hunting season. I was running late because I had to stop and help one of the other guys.
He went in my shop and grabbed that drill and adapter. I outweigh him by about 100 pounds.
When I got there, he was sitting on the ground holding his arm. The drill had thrown him about 10 feet.
He had a hold of the side handle, but it just overpowered him.
I love that drill.
BTW, the keyless chuck works great on it too.
But don't get the wrong idea. I don't think Milwaukee makes a bad corded drill. Some are just stronger than others.
