You think that is outrageous
Here you go:
http://coloradok5.com/forums/showthread.php?t=278856&highlight=peugeot
Would the 4l80e be the only reason to get a 91? Couldnt I get, lets say an 1989 and just put in a 4L80E? Or is there other reasons? Thanks
That and it is the "newest", not a real big deal. As far as the trans swap, very spendy.Would the 4l80e be the only reason to get a 91? Couldnt I get, lets say an 1989 and just put in a 4L80E? Or is there other reasons? Thanks
Does the 4l80e come in the 1/2 tons or the 3/4 tons only?
I like the idea of an overdrive, but would prefer a 3/4 ton. Are the 400s alot stronger than the 700r4. Could you put a 700r4 in a 3/4 ton for the overdrive or is that just stupid. I also do want TBI.
honestly it dosnt matter. find a sub that has a solid body, and options you want. even if you buy a 1500, the 3/4 ton axles are cheap and bolt right in. my logic is 1500's were more likely the grocery getters, and led sheltered lives. the 2500's were probably the work horses. and got abused more.
