*Registered and insured as a 1980 GMC Jimmy
*454 tbi
*th400
*homemade 203/205 (whole driveline dropped about 8" and pushed rearward about 9")
*dual optima red top batteries
*shorty headers with full 2.5" aluminized dual exhaust with 2 chamber flowmasters
*warn 12000lb winch with removable cradle for mounting in rear (recessed in front for better approach angle)
*driveshafts - 1350 cvs with 1410s on the axles, long slip from jesse
*60 front with 35 spline outers & cage diff guard - welded
*14 bolt with disks & cage diff guard - detroit
*full hysteer setup with hydro assist, ram from northern tool and homemade reinforced hysteer arms/tie rod/drag link using stock 1 ton chevy tre's
*4" skyjacker softride front springs with dropped mounts and some revolver shackles i made
*10 point cage with racing seats
*4 core radiator with dual electric pusher fans from a fiero
*aluminum fuel cell mounted up in the rear along with spare 44" bogger
*44 - 19.5 - 16.5 boggers
*full set of autometer gauges
*Hurst ratchet shifter
i did all the fabrication with a 250 miller mig while i was in college a few years ago.
all the bushings on the rear suspension are plain old poly bushings with the wide shoulders (from Stephen's place). i have run them without any problems so far. the 'buckets' on the axle end of the springs were made to pivot in all directions to not cut down on the amount of flex. i am very happy with the design.
