fabjunkie
I'm sure I'm not the first to battle these stupid plastic retainers for the headlight adjusters. The old white ones have decent thread engagement and seem to hold well. Problem is that they get brittle and break when you change out a headlight. The new black ones that are available have hardly any thread engagement and seem to strip as soon as you put the spring on.
Because of this I wanted to use a T-nut...
But could not find any local and they are probably some $ if you can find them. The other problem would be finding them in the 1/4-28 thread that the adjuster bolts are.
After doing some running around and looking at different options I came up with this.
(8) 1/4-28 Nuts
(8) 1/4 Fender Washers
$1.48 total at Ace
Tack the nuts to the washers and you end up with this compared to the ****ty plastic ones.
You will have to bend or cut and edge off the washer for the top bolts. I didn't and will see if I end up having to pull them back out. I like this much better as they are not going to strip out and the width of the nut fits the hole in the core support perfectly to keep it from spinning while adjusting the headlights. I have to wait for it to get dark out so I can adjust them, but I'll be happy to not have my headlights pointing at the ground directly in front of the truck.
(8) 1/4-28 Nuts
$1.48 total at Ace
there are 3 listed. Do you know which one sir? Or maybe I'll call the company at some point to find out and report back.
