1 piece or 2 ?
Yeah you did use HAD for the flange. I think PM flange is the same Paradise & Auburn are 20-30 minutes away from each other.
I guess I just get a SD shaft and measure be I order a flange
I was at Parts Mike last week. HAD is over an hour away from PM though....
Ordered a SD shaft from flea bay 124.00 delivered, will get a flange to match then get JE Reel to re tube it. they are local to me. They have heeps all over their web blaa :doah:
Friday my flange arrived. I pulled my old stuff, mocked up the new setup, came up with 63 1/4". Grabbed the evil bay super dukey shaft and headed down to drive shaft shop for retube.
The tube diameter is to small to do 63" safely. Having a 4" tube shaft built, 1350 u joint, slip, and cv with 2" pilot 4.25" bolt circle.
Should be ready Wednesday.
Saving the other shaft for the front, when I get there.
