My k20 Burb with 4" lift, has a 2 piece rear drive shaft. I shortened/balanced the short fixed half after the 700r4 trans plant. I have adjusted the center support bearing by shimming it various heights. I have drive shaft vibrations at various speeds.
In the near future ( i hope) I will be installing 4" shackle flip and 56" stock rear springs. I know the slip yoke on rear half of the shaft is barely long enough for the lift w/o wheeling. I expect to have a new shaft made when I do the flip.
The question is 1 piece or stay with the 2 piece ? what is the longest 1 piece shaft advisable. I can and probably adjust pinion angle at same time. If I can do a 1 piece shaft should it be CV ?
What are the CC long beds using for a rear drive shaft?
