1-Ton K5 for sale on 47'' LTB's TEXAS
OKAY FELLAS THIS IS MY RIG
RGV72BLAZER THANKS FOR POSTING IT FOR ME BUDDY:D
okay guys im thinking about parting it out anybody interested in parts
You bought that to part it out?
Ok, how much for the crossover steering arm and draglink, front diff cover, and if the rear ORD shackle flip will fit an 87' burb?
Also the rockstomper rock rod and the alternator?
pm me for details. Thanks.
no it's my rig and always has been, im just checking to see if its going to be worth doing it,
the axles will stay together complete
Is this a joke. Sweet rig! Why didn't you post it then? You wouldn't get 13k parting it out.
I know there is a bunch of money in it, but you will never get it back. Good luck in whatever you do.
no its not a joke it is just easyer to buy in parts then some body coming up with 13k
i wasnt a donating member at the time David did me a favor by posting it
Now I get it. Good luck. You have a shietload of part I want/need.
Posting this for a buddy of mine so contact him, his # is posted in the ad:::
EDIT:::8/10/10
It also has a 203/205 doubler, 1410s all around, and triple sticks
NOW ASKING 13K FOR THE BLAZER & TRAILER TOGETHER
1979 K5 Blazer w/ a 84 front clip. I put this front clip so that I could narrow It for Rock Crawlin' Full Sizes are just a little big for tight trails.
I narrowed It 18.5'' In the front & 18.5 In the rear, then I bobed It right behind the rear leaf spring, then I chopped the top.
The Power Plant Is a 82' 454 BIG BLOCK Bored 30 Over, Balance, Blue Printed, & Puts out 468 Horses.
cooling it down is twin monster fans with built in fan shroud
dual yellow top optimas
165 amp alternater chromed out lol
TH400 transmission with revers manuel valve body ART Car Gate shifter
Aspiration Is Propane Injection 20 gal tank.
Suspension In Front Is a 8'' skyjacker but has been modified to 7'' by removing 1 leaf from the pack
Rear Suspension Is 4'' ODR shackle flip, 2'' boner leaf, 1'' zero rate, 56'' leafs
Front Axle Is a 82'' D60 LOADED w/ 5.13 gears Full Detroit Locker, Drive Flanges & 35 spline inners/ outers Youkon cromo's. shafts CTM's U-joints) BTF Diff cover.
ORD crossover steering, Home Brew Ram Assit, Rock Rod from Rockstomper
Rear Is 82'' corperate 14 Bolt FF that Is LOADED w/ 5.13 gears Full Detroit Locker, & has been Freshly Shaved! for Ground Clearance,Disc breaks BTF Diff Cover.
The shafts are Square Drive Shafts, not round tube. they are made out of 2''x2'' 3/16 steel out side, & 2 1/2''x2 1/2'' 3/16 steel out side. MADE by DRIVE SHAFTS UNLIMITED
2 pair 1410 spare drive shafts w/ U-Joints so If I break I can change the broken side fast & get back to the trail. In case I break this works out well cause my F/R Shafts are the same measurement.
Tires - 5 new 47''x17.5 R16.5 BIGGER, LTB, SUPER SWAMPERS they are wrapped around steel Trail Ready Bead Locks 16.5''x12'' w/ a 3.5'' back space i grooved the tires but i havent ran it sice i grooved them i have to say the tires are 97% tread hight
16,500ti Front WARN winch, w/ all the goodies.
10,000i Rear WARN Winch
60'' high lift jack
Custom Dash Board made out of (alum a-lite sign board) since I make signs for a living, push button start, 2'' 5/8 auto meter gauges w/ a 5'' monster tach w/ a shift light.
Seats: for the front came out of a 01' Chevy TRUCK, the rear seats came out of my WIFE'S 02' Tahoe 3rd Row
Custom Paint Job!!
13,000 get's it........................opening a new bizz so im selling i can build another one later
I also have a 32' Goose Neck Trailer that I will throw in for 3500 dollars more!!
Serious inquiries only!!
i will consider a trade for a Polaris RZR with 28'' tires
Please call or text Gabe 210-744-3191
I hate to see this truck get parted out, I've always thought it was a fantastic rig.
that said...
How long can you wheel on the 20 gal tank?
Can you shoot me a price for the propane set up?
Also, what pieces did you use for the hydro assist? Price that also.
John
