10 bolt, 4.56, detroit, discs, tires, wheels, tcase, etc....
K5Chris
Texas
custom sub box for 88-98 Chevy/GMC extended cab 2 AND 3 door trucks, and fits 2-10" subs..... $45
NP241 passenger side drop Tcase w/ adapter to bolt right to 700r4 or 4L60. has bent output shaft. perfect if you want to install a slip yoke eliminator.... $250
stock 10 bolt pinion yoke..... $10
10 bolt rear differential cover....... $10
*the stuff below is still on my truck..... I am upgrading my axles, wheels & tires..... so, this stuff will be for sale within the next month...... let me know if you are interested....
(2 sets) 4.56 8.5" 10 bolt gears..... $75
Auburn limited slip for 30 spline 8.5" 10 bolt...... $170
disc brakes for semi floater axles with brand new pads, rebuilt Mustang SVO calipers ready for Ebrake, & resurfaced rotors..... $150
2 sets of 30 spline 6-lug 10 bolt rear axle shafts......... $45 per pair
10 bolt or Dana 44 6-lug hub/rotor a$$emblies: come with wheel studs, big bearing spindles, bearings, and caliper mounting plates (dust shields)........... $50
4.56 THICK gears for 10.5" 14 bolt FF, brand spankin new in box...... $200 shipped
spider & side gears for 10.5" ff 14 bolt....... $30
complete 2.5" lift kit w/ 2.5" front springs, 2.5" rear blocks, and all u bolts.... $100
2-Rancho RS9000's & 2- rancho es3000 (pro comp) for 2-3" lift..... $100
half ton spring plates (good for U-bolt flip)........ $15
stock 10 bolt steering arm...... $25
4- 33x12.50-15 BFG A/T KO's with 50% tread......... $250
4- 15x10 American Racing chrome modular 6-lug wheels....... $100
1- 33x12.50-15 BFG M/T on matching 15x10 chrome mod (tire only good for spare) $40.... or free with purchase of tires & wheels above (all 5 still mounted & balanced for $350)
*all prices do not include shipping
[ QUOTE ]
2.5" cast iron lift blocks with U-bolts......... $20
[/ QUOTE ]
Are these angled/tapered? Pic?
Shipping to 46041?
[ QUOTE ]
I might be interested in the gears if you get them removed soon enough
[/ QUOTE ]
it will probably be about a month
[ QUOTE ]
[ QUOTE ]
[/ QUOTE ]
Shipping to 46041?
[/ QUOTE ]
no, they are not tapered, they are flat.
i ship via fedex ground and they are very reasonable. probably somewhere between 4 and 8 bucks. i cant tell you exactly yet case they are still on the truck.
[ QUOTE ]
where in texas are you?
[/ QUOTE ]
north side of Houston
i forgot to mention, the np241 is out of a '91, so it has the electronic vehicle speed sensor, not the gear/cable setup. it does have a bent tailshaft, so it would need a new tailshaft or slip yoke eliminator kit. i have not run it, so no guarentees about it.... it might need a little reuild.
i would rather not ship the larger heavier items like the axle assembly and the tcase. it looks like i'm going to part out the 10 bolt rear anyways.
what would the shipping be on those 4 wheels be to 18235? Also what condition are they in; and when would they be ready for shipment? Thanks... /forums/images/graemlins/thumb.gif
wheels are in very good shape. most of my new parts should be here within the next week.... so, probably 2-3 weeks.
Any idea when these gears will be avail? Dont mean to rush but I am about ready to order.
[ QUOTE ]
[/ QUOTE ]
i'm sorry, it will be another couple weeks. i keep changing my plans.
i will have 2 sets of 4.56 10 bolt gears, and a 30 spline Auburn LSD.
How well does the Auburn LSD work? How many miles are on it, and was it in front or rear? How much would you want for it shipped to 27217 (Burlington, NC)?
Thanks!
Richard
[ QUOTE ]
[ QUOTE ]
[/ QUOTE ]
[/ QUOTE ]
Ok if it's only going to be a few weeks I can wait, will you let me know if plans change. Thanks
Adam
[ QUOTE ]
[ QUOTE ]
[ QUOTE ]
[/ QUOTE ]
[/ QUOTE ]
Adam
[/ QUOTE ]
no problem..... i'm planning on going on a weekend offroad trip oct 8-11, so i have to get er done before then.
[ QUOTE ]
Thanks!
Richard
[/ QUOTE ]
the auburn is an aftermarket limited slip that uses clutches and 5 springs to transfer torque. it is VERY tight. the Auburn is one of the best, if not the best limited slip on the market. it is in my front axle, and gets very little use. i rebuilt it last year, and it's in great shape. it is 30 spline, so if you have a pre 89, you'll need to get some 30 spline shafts. i will have 2 sets of 30 spline 6 lug rear shafts for sale. i am looking to get $170 for the auburn. i would estimate shipping to be about $10-15, if it's more, i'll cover the rest. and, i want $45 for each pair of rear shafts, no idea on how much to ship those.
http://www.auburngear.com/aftermarket/products/differentials/
[ QUOTE ]
[ QUOTE ]
[ QUOTE ]
[ QUOTE ]
[/ QUOTE ]
[/ QUOTE ]
Adam
[/ QUOTE ]
[/ QUOTE ]
Great then put me down for both sets.
