10-bolt 8 lug conversion stuff....or a Dana 60 cheap... 4.10 ring & pinion
garydan
Port Saint Lucie, Fl.
Well I need to get the front axle of my blazer to match the 4.10 14-bolt FF axle in the rear. I can't see to find a D60 around here. Let me know what you have.
Thanks.
I have the 8 lug conversion stuff on a front 10bolt here,i need to check the ratio. Shipping is going to be a little high due to weight of rotors. I am willing to take it apart. The rotors and backing plates is all you need,calipers are the same,spindles are the same,cone spindles and lockouts are the same. I will let you know ratio sunday night.
