As the title says... I've seen these, but not necessarily for a 10-bolt. Also, I'd like a magnetic drain plug at the bottom.
Suggestions?
Suggestions?
readymix said:get a new diff cover and weld them in.
Probably not real necessary . If you don't peel the cover on rock , and if you went with new axle seals they should take a long time to leak out when flexing .
, the axle failed because of a leaking pinion seal, which caused major fluid loss. Strangely enough, after it was refilled and driven 200+ miles to get back to ATL, it showed no signs of leaking...
you have a level checker, its that fill plug. stick your finger in there and check level and condition. also you can get those cleargearz covers.
get one, and all the parts, and I'll weld it for free. Just ship it to me.
Flat rate should be around $10
True... but I'm not taking chances. Reportedly, according to Pep Boys, the axle failed because of a leaking pinion seal, which caused major fluid loss. Strangely enough, after it was refilled and driven 200+ miles to get back to ATL, it showed no signs of leaking...
Could probably fab one using parts from an oil dip stick welded into a large bolt. I am sure there are 100 different ways to get it done.
this reminded me of Michael(supreme70')'s bad seal.As the title says... I've seen these, but not necessarily for a 10-bolt. Also, I'd like a magnetic drain plug at the bottom.
Suggestions?
remember the JELLO he had in his rear diff?You certain you ain't loosen gear oil inside the axle tubes? Please excuse me but a dip stick on a dif sounds laughable. I thought you were joking at first. Why is turning a cover plug out to check condition and level so hard? You are only going to use it a couple times to establish you either have a leak or you don't. If you do have a leak then you'll fix it rendering the dip stick pointless after that.
