iirc, nascar guys put a small pump & cooler on their axles...
If it's that big of a problem you may want to consider that...the pump runs off of a fan belt driven by the driveshaft or yoke
edit: apparently they have an internal pump now...
Might even look into that high temp grease too. All I ever use (not that I've had a problem) is whatevers on the auto parts shelf.
