12 bolt front
rick4x4
SHREVEPORT, LA.
Can some one tell me how hard it is to find a 12 bolt front end for my 85 K-5 and about what it should be$$$$. And will it be worth the time to swap my 10 bolt for the twelve bolt both front and rear. Some one said that finding a 12 bolt w/373 in it would be really hard to do because there are not that many 12 bolt fronts around.
Thanks
Rick
The only 12 bolt fronts you will ever find are not factory. They are a custom made axle.
See <a target="_blank" href=http://coloradok5.com/gallery/Waynes-Toy>Project Mighty Mouse</a> here.
<font color=blue>Wayne<font color=blue>
<font color=blue>Happy Trails<font color=blue>
Definately isn't alot of front 12 bolts around. Infact I have never heard of it. Good luck.
350FI/700r4/NP208c/10b's ORD 4" Shackle Flip/ORD Disconnects <font color=red>NJK5</font color=red><a target="_blank" href=http://groups.yahoo.com/group/njk5club>http://groups.yahoo.com/group/njk5club</a>
I got this interesting tidbit directly from Grim-Reaper.
<blockquote><font class="small">In reply to:</font><hr>
Last guy that I ran across on the POR board that thought he had a 12 bolt had a 10bolt with GM12 cast into the side. Somebody else woke up and figured out where the guy was getting "12" from. I had completly forgotten that was cast into many of them. It's on Jan's 79. I haven't looked to see if it's on this 10 I just swapped into my 75.
<hr></blockquote>
Kinda explains the confusion. The 12 bolt front unless custom made does not exist.
Rene
<font color=green>Dyslexics of the world...UNTIE!</font color=green>
<a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
GM12 is cast into the carrier on the 10-bolt front end out in the garage.
Only see GM 5 and the casting numbers on the housing though.
<font color=black>HarryH3 - '75 K5</font color=black>
<a target="_blank" href=http://www.angelfire.com/super/ThunderTruck>www.angelfire.com/super/ThunderTruck</a>
It's a great day to be alive...
It's a unicorn. You come up with one I'll give you 50 bucks. It has to be a GM axle and it has to have the 8 7/8 ring gear just like a 12 rear.
Women dig dents and flat paint!
coloradok5.com/gallery/Grim
75 Jimmy, Dollar
Grim-Reaper
The 12 bolt front doesn't exist, plus the 12 bolts are only slightly stronger than your 10 bolt. There are really only 2 other options for front axles. One is the Dana 44, which isn't much stronger than what you have now and probably isn't worth swapping unless yours is broken. The other option is the Dana 60, this one is very strong and is worth it if you can afford it, usually start at about $1000 used. There are other axles that can be used, but they're not as common.
73K-5: TBI350/TH-400/NP-203/14FF/D44
Topless, doorless and no tailgate!
Fresno, CA
get 2.5 ton rockwells.
Sherman, Tx
<font color=red>The blazer's almost on the road....anyone got tree fiddy?</font color=red>
i saw someone break one of those rockwells at the Warn Rock Crawling Championship i'll see we got a pic of it or not if we did i'll post it, some crazy stuff man
<font color=purple>I put the Panic in Hispanic</font color=purple>
<a target="_blank" href=http://4x4.alloffroad.com>4x4.alloffroad.com</a>
Whatever Executioner...post some pics.
Rene
Prolly not worth it.
Since they are hard to find
it will be hard to find parts so you're better off with a D60 if your willing to do that much work
Peace and stuff
Muddin
<a target="_blank" href=http://www.geocities.com/muddin4fun79blazer>www.geocities.com/muddin4fun79blazer</a>
Alright!!
Executioner is baaaack!!! And with his "so-called 12 bolt front axle"!!!
Come on, man! I'm not picking on you!! Just want to see the pic of it.
Get the pic posted, (up close - so we can see a good pic!) and I will send you $20 for your troubles. (only if it IS the 12 bolt front axle!)
I'm not picking my nose...I'm just pointing at my brain!!
<a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>The K30 Collection</a>
Executioner, pictures please!
Fresno, CA
<hr></blockquote>
Wes...shouldn't you be pointing towards your ...uh ...well ....nevermind
Peace and stuff
Muddin
i read somewhere that the truck 12-bolts are .125(1/8) inchs smaller than the car 12-bolts. just curious if you know if that is true
<font color=blue> If sancho knows what good for him, he best go run and hide. Cause daddy's got a new 45.</font color=blue>
i pm'ed him askin if i could see his infamous 12 bolt front...doubt he answers
Mash Out!
82 Blazer 1 Ton "Big Nasty"
78 Jimmy 3/4 Ton
<font color=red>"Red Dawg" </font color=red>
