My 70 k5 has an open 12 bolt that has dark specs on some of the ring gear teeth. Would even call it mild pitting. Has 3.73 gears. Just pulled the 12 bolt from my 72 K5 and found it has a gov-lock but 3.07 gears. SInce It looks like I'm going to need a new set of gears anyway, which rear end should I put them in. Stock 350 with th350 and NP205, tires no bigger than 33 (keeping the 3.73 ratio). Shouldn't be wheeled hard. Looking for opinions. Frank
