12 Bolt rear u-bolt size
Cricket
3/4 ton status
Colorado
Off the top of your head, what is the u-bolt size for a 12 bolt rear axle.
NAPA wants an ID size.
Well a quick online thing where they say to measure for buying a u-joint , says a 1310 ( 12 bolt auto ) is 3 7/32 x 1 1/16 .
Umm, are we on the same page? Are you talking u-bolt to bolt the axle to the springs or u-joint for the driveshaft?
I thought he meant to say u-joint . I didn't know NAPA sold u-bolts . We always used used ones , went to Spectrac ( local spring and RV shop ) , or called a 4x4 vendor .
According to my search for U-bolts via Trailmaster. A u-bolt for 0 to 4" lift
Inside width is 3" - 3.625"
Inside length is 8" - 10"
I'll try and confirm that tomorrow when I can see something.
I got lift u-bolts for blocks on a 12 bolt . I got regular ubolts for a 12 bolt with lots of leaves .
Want any ?
Want any ?
Yes, you gots the PM.
We can also get them made on the spot here in Greeley. IIRC when we made them for Nick it was $9ea. Plus we have the old ones in the yard they can use for "templates."
