ccarley
I'm planning on replacing the wheel bearings on my rear 12-bolt this weekend. I know, the '89 model year did not come with a 12-bolt, but I got one dirt cheap and swapped it in place of the worn 10-bolt. Everything in the middle of the axle is new basically, except the R&P. Carrier bearings, pinion bearings, and Detroit/Eaton True Trac.
I'm pretty sure the wheel bearings are shot; there's a bunch of noise, especially over bumps, and the top of the wheels point in a tad. So, I have in my hot little hands, new bearings, seals, and a gallon of gear oil. Also coming, new brake shoes, and of course new cover gasket (2 for safety).
Here's the trick: I know I need a slide hammer for the job. I do not own one, yet. I'm looking at the harbor freight one (of course), and for $20 I can get a "kit" with stuff that may or may not work.
http://www.harborfreight.com/15-piece-slide-hammer-and-puller-set-5469.html
They also have the special bearing puller attachments, sold separately.
http://www.harborfreight.com/rear-axle-bearing-puller-set-66380.html
Is it worth the extra $30 for the bearing puller attachments? Or will the (what looks like) 2-hook puller attachment work OK?
Maybe? Maybe not? Risk it Saturday morning & see if I need the other attachments? What would you do?
Thanks,
Clay
Thanks,
Clay
I have to drive this Monday... They didn't have a pair of the Timken repair bearings, so I had to get the Durlast ones. They are odd, with an inner seal?
