14 BFF 4.56 thick gears
sandy78
Utah
How can you tell if you have the thick ring gear for the 4.10 carrier, or the standard thickness for the 4.56 carrier? Does anyone have a quick measurement? I'm trying to identify. Thanks in advance for any help.
Thanks for the suggestion. I found a pic of cases, but not of thick vs. thin ring gear. To clarify, I have a ring gear that the guy I got it from said was a thick gear, but I don't have any way to verify other than to try to install it. I was hoping for a quick height/thickness measurment so that I would know if it was truly thick before I tear everything apart. The markings do not help. It is a 4.56 ring and pinion.
Thanks!
a regular ring gear is just over an inch thick. a thick gear is around 2" thick.
