yeah just put it under and go from there, im sure several of us want to kow how it turns out- as far as driveshaft length goes
before i brought out the tape measure i made the assumption that the 14 bolt FF would have to need to have driveshaft shortened- i figured this because its a big axle compared to the 10 bolt it was to replace- but when i measured i found that it would need a longer shaft instead, so i was like, "uhmmmm, ok.... this isnt a good thing, hmmm..." and then i measured on the dana 60 ff i had next to it and it was basicalyl same measurement as the 10 bolt, like maybe 1/4" difference.. wierd..
ive got right about 12.5" on the 14 bolt ff from the centerline of axle tube(leaf pack center pin) up to the yoke where the caps bottom out
good luck
