84400
Registered Member
I have done a bit too much reaserch on this topic trying to figure out what will work best for my needs. Being a SM465 truck and driven on the streets it needs a working ebrake. So here is what I am thinking about...
First is used caddy calipers. Hard to find and everything up here is rotted and only good as a core if you can even get the levers apart...
Napa has them on its site for $78.00 a peice rebuilt but with out springs and levers which i have heard you can get from blackbirds.
Second option I am looking at is these:
http://www.circletracksupply.com/gm...ar-disc-kits-on-3-4-1-ton-pick-up-trucks.html
The big advantage of these over TSM is that they have the cable mounting built in and are the same price. Also the bleaders are at the top of the caliper when mounted up allowing for easier bleeding. $320 is alot for me to drop when i would rather have a yukon grizzly for the rear.
Has anyone ran the circletracksupply calipers? Good/bad? Any other thought or opinons?
thanks
thanks
