garydan
I bought the chevette lines, as you can see here. I need to find weld-on tabs (or another solution that doesn't require welding if possible). I also need to replace the "t-connection" at the top of the pumpkin. Here is what I have so far:
Should I weld tabs onto the spring perches? Will the chevette connectors go right into the tabs or do I need some sort of adapter? From the looks of it, all I need are the tabs and the clips and I'll be fine, here is the end of the chevette line for reference:
After I mount those, I'm going to have to run hardline up to the top of the pumpkin where I'm going to need a new t-connector. Can someone send me a part number or a weblink for a new one? They don't have them at autozone and I'd rather not use the connector in the truck right now.
Does autozone typically carry the weld-on tabs and clips? Or will I have to order those online?
Thanks for all your help, I'm determined to get this 14-bolt in the truck by next weekend
