pseudomike
I'm looking to upgrade to heavier axles on my car hauler and I was thinking about cutting the tubes off a couple 14 bolts and fabricating new axles. Basically plan to cut tubes at the housing and weld new DOM tubing (either over existing tubes or inside depending what I can find) to extend them to length. From there I would cut the axle shafts off and use them like a bolt on dust cover. Would run standard 14 bolt brakes, seals, bearings, and more importantly same spare as the truck. I was thinking I would put a hydraulic brake actuator on to run the 14B brakes at the tongue and ditch the finicky electric setup I have. What do you guys think? I've used 14B outers for other projects and I know they can take serious loads. Just a thought, wanted to get some input.
