My 14 bolt axle is leaking from the pinion carrier, so while I'm at it, I want to replace the pinion seal too.
So, can I just unbolt the pinion carrier, install a new pinion seal, then apply some silicone onto the mounting surface of the pinion carrier(is there a gasket?) and slap it back together using an impact to tighten the nut that hold the yoke on? Or, will I need to torque it to a specified rotational torque? (the amount of torque it requires to rotate the pinion)
I attempted a look into the 14 bolt bible, to no avail. It just listed rebuild procedures.
Thanks in advance.
Thanks in advance.
