Dheater
Registered Member
Looks like theres the mounting bracket and 2 spacers between it and the axle mounting. If you halved the bracket in the pictures and used 1 spacer between the new bracket and the current bracket it "should" mount up on the inside of a ruffstuff bracket thus making it compatible (if you're accounting for the 3/8" thick ruff stuff bracket, though i dont know the materiel thickness of ORD or DIY4X brackets).
Ive got ruff stuffs brackets on my 14 bolt and I'm local (monument/springs). I've even got the stock ebrake cable zip tied under the truck. Let me know if those dudes want to use my setup as a template. I'd even do it out of the goodness of my heart and wouldnt even ask for a discount should they can figure something out.
.....................ok so i might not be able to live up to that last sentence.
this is a dual caliper bracket, I do not think cutting it half would work. I hear you on the discount...
. I haven't tried it.
