14 bolt semi float?
Theres a post in here by Dyeger, Dontoe or Divorced about the 14SF. Lot of specs and good info..
On the newer 88+ trucks you may have to move the spring perches or shock mounts.... Never measured the mounts ont he one I had... And I ithink most had a larger u-joint...
Dyeager has it. Search for "14sf tech" any 14sf before the 88 one will bolt in.
Also, I would say that 70%, from what Ive seen, come 8 lug, so you might have to buy new shafts if you want 6 lug.
i believe irving is up my dallas, if so its about a 3 hour drive....but it would need quite a bit of work to drive it home....mostly a tranny and t-case....also i think one of our fellow members is pretty set on buying it...sorry
