As OBIJAUN said you’re very close.
Make certain that you are giving enough resistance ( big rag or old T-shirt watted up against the ring gear as you spin the pinion ) in each direction to get the most accurate pattern results.
Once the pattern is reading great and the backlash is 8~10-ish set bearing preloads and all is well.
Looks like you are doing a fine job so far!
