I used billvista 14 bolt bible torque of 50ft lbs on my spindle nut. It feels pretty tight, takes a little bit of force to turn the 38’s by hand and i cant turn the axle at all by the pinion by hand.
not sure if this is normal and will wear itself loose, or if this is a torq like other axles where you torq to this, and then back it back out to hand tight and call it good.
Im running a 14 bolt out of a 2004 2500, not sure if this makes a difference aswell. I completely rebuilt the axle, new bearings, seals, locker, crush sleeve eliminator, new HD pinion yoke,
