It definately needs more grip i could see it spinning because the spindle was grabbing it more, as i rotated while torqing, i shouldve pulled off right away, but i was ready to get tires on so i could start getting other things done.If you remove that hub again, use a pointed punch and put a couple of dozen dimples around the surface the seal sits against. The dimples will help to make the surface "grip" the seal, people do the same with bearing races that no longer have a perfect press fit. Also, put Loctite on the seal instead of RTV.
Bout ready to get back to axle though and burn perches in. Getting closer to using it for sure i need to update my build again.
