5.38 is max and needs little case work to fit.
also http://coloradok5.com/forums/showthread.php?t=151608
so is there a way to know which one I have? And if I have the 4.10 one I can still run lower gears just need to get a special gear?
It had the 41 10 so must be a 4.10, but does that mean I cant run 4.56 gears? Sorry about all the questions but this is my first 14 bolt
thanks
is there any disadvantages to the thick gear? And do you guys run disc brakes on them or leave them drum? This rig will be in mud not rock crawling if that makes a difference
Thanks this has been really helpful
i've beaten the hell out of my thick 4.56 r&p so far and no carnage. burnouts on dry pavement, brakestands, etc etc on 38's. more material should equal more strength, i would think.is there any disadvantages to the thick gear? And do you guys run disc brakes on them or leave them drum? This rig will be in mud not rock crawling if that makes a difference
